I have multiple 1750HP, 4160V synch pump motors. I am protecting them with a Multilin 469 relays. What is a typical setting for power factor trip? I currently have them set to trip at 0.95 lag after a 1 second delay. I am starting to have nuissance PF trips on the running pump when I try to start a second pump. The running pump trips on a PF. The second pump keeps running! The voltage on the running pump is around 4000V when it trips on PF. Can I lower the PF and/or increase the delay without damaging the motor?
Thanks
Thanks
