- Bremerton, Washington
- Master Electrician
Looking for a source for a Syncroscope to sych two 3 phase systems. Are they available in a portable version?
Did you ever see the way we synchronized in the old days, with a set of three light bulbs? We'd adjust governors until the beat frequency between the two sources was close enough that the lights slowly cycled from bright to dark and back. Once this little light show was sufficiently stable, we'd time the dark period once and the next time the lamps went dark we'd wait half the period we timed and slam the tie breaker shut. It was quite a thrill, especially when the machine was big, the other source was the utility, and you missed by a few seconds....
I think they did use a set of lights at one time to sync generators. You could set them up so you were in sync when the lights were out, or when they were at full brightness.
From a thread on eng-tips.com
