KarlS
- Houston, TX
I have a question concerning neutrals from separate systems in the same wireway. I have two 45KVA transformers feeding two separate 102/208V panelboards. Each panelboard feeds separate lighting and receptacle circuits. My inspector stated the neutrals must be different colors per article 200 of the 2005 NEC. The installation is in an industrial metal interlocking building. This will be located within a plant. I don't see why the neutrals must be a different color for a lighting ckt from panel 1 vs the lighting ckt from panel 2. Yes, they are two separate systems but of the same voltage. (120Vac) Is this inspector correct? Art 200 starts - All premises. This is an industrial building.
