Who is a miniature bulb guru?
I'm dealing with under cabinet fixtures (120 volt) that are labeled "Max. 35 watt type T4 lamp".
I have seen 2 blister packs of halogen lamps with what both appear the same, except one is marked G8 base and one is marked GY8.6 base. What is this base spec referring to (I suspect a milimeter measurement)?
Are halogen versions of a 120 volt T4 lamp dimmable? TIA.
