stevebea
- Southeastern PA
Situation is linear lighting in a retail space. Customer wanted to dim these lights so one of our guys installed Advance Mark 10 ballasts ( 2 wire dimming ballasts) and a Cooper AF10 dimmer. The dimmer is rated is rated 8.3A and actual load is 6.75A. The problem is the lights will occasionally pulse as in the lights will get brighter for a split second . It usually does this two or three times in quick succession and then settles down and may not do it for another 45 minutes. The only thing I found was that when the dimming ballasts were installed the sockets were never rewired so the sockets were in parallel ( shown on ballast ) instead of being in series. Could this be the root of the problem? The ballasts and dimmer are compatible according to both manufacturers. Any input ? Thanks.
