:-? Table 250.122
1600A OCPD
4 sets of 3-750kcmil al conductors+grd.
Or
4 sets of 3-600kcmil cu conductors+grd.
250.122(f) Conductors in parallel:
?Each parallel equipment grounding conductor shall be sized on the basis on the ampere rating of the overcurent device protecting the circuit conductors in the raceway or cable in accordance with table 250.122?
So this indicates that for a 1600A OCPD a #350kcmil al or 4/0cu conductor is required for the equipment ground conductor. The statement above indicates that each conduit must contain the conductor, so each set of 750?s al would have a 350grd, and each set or 600kcmil cu conductors would contain a 4/0 conductor. I wanted to make sure I was reading this correctly. This is the way I interpet it, however someone in our office indicated that for paralleled conductors you would take the 350,000 and divide it by the number of sets (Ex.4) 350,000/4 = 87,500 per set of conductors and that would work out to a 1/0 in each set inleau of a 350kcmil in each set I believe he is incorrect. Looking foreward to you opinions.
1600A OCPD
Or
