fc
- New Jersey
When you size the GEC for a separately derived ac system (Transformer) Do you size it to the Primary conductors or the secondary conductors?
A ?transformer? is not a ?separately derived system,? any more than a ?heat pump? is a ?HVAC System.? But a separate system can be derived from a transformer, and that transformer will be a component of the ?separately derived system.? This is from the Article 100 Definitions:Originally posted by bennie:There is no reference, in the code book, that a transformer is a separately derived system. I challenge anyone to prove the grounding requirements for a separately derived system have anything to do with a transformer.
Your last sentence is not correct. This is the point of the argument. Simply stated, take a true isolated transformer, winding voltage to winding voltage,(magnetic coupling only) no grounding, and you have an SDS. All others, although maybe not auto transformers by definition, do have a common connection, more than magnetic coupling.In reality the earth is a grounding conductor. While soil is not the best current carrying conductor, it is required to be part of electrical systems. Therefore there are no separately derived systems
