- Massachusetts
I was shown this by someone at work. It is a Table saw that can sense when it hits flesh, then stops and retracts the blade in an instant.
Sawstop
Check out the video on the bottom right of the page called "An Inside Look"
It seems like it works the same way as a 'touch lamp'.
I found it interesting, thought some of you might as well. :smile:
Sawstop
The SawStop safety system includes an electronic detection system that detects when a person contacts the blade. The system induces an electrical signal onto the blade and then monitors that signal for changes. The human body has a relatively large inherent electrical capacitance and conductivity which cause the signal to drop when a person contacts the blade. Wood has a relatively small inherent capacitance and conductivity and does not cause the signal to drop.
