Tankless water heaters or recirculating pumps on GFCI?
jango
Does a tankless water heater or a recirculating pump that are located in a garage need to be GFCI protected? I've heard from some that they do not and that it's not recommended to do so. Thanks for your input.
If they plug into a 120 volt receptacle then they must be on a GFI. If it is direct wire then no it does not need to be GFI protected.
