eager2learn
- Mennifee,Ca
today i went out to a service call involving a circuit breaker popping every now and then when a tanning bed would be used. i think that the problem was that the circuit the bed was on was only a 15 amp circuit. i did some diagnostic work with a meter and found that with the bed on by itself it took around 11 - 12 amps. there was also bathroom lights, doorway lighting, and a office that was used only for the internet. when i turned on everything at once the meter showed that there was about 13 amps being used. the wire was #12 so i installed a 20 amp breaker to take care of everything. the other thing that came to mind was ambient temperature because the panel is located where the sun hits it directly for more than half of the day. i was just wondering what you thought about this application with all this in mind.
