S Schwinn krate Member Location Nyc Occupation Electrician Jan 15, 2020 #1 What size drill and what size tap do I need for 3/4 gal pipe. I am using a brass box that doesn't have any knockouts. Thank you
kwired Electron manager Location NE Nebraska Occupation EC Jan 15, 2020 #2 Depends on some things. A chart I looked at says 57/64 with taper pipe reamer, 59/64 w/o taper pipe reamer and 15/16 for straight threads.
S Schwinn krate Member Location Nyc Occupation Electrician Jan 15, 2020 #3 I'm curious myself. I seen that. Just wanted to make it right before I drill and tap. Thank you
H hillbilly1 Senior Member Location North Georgia mountains Occupation Owner/electrical contractor Jan 15, 2020 #4 Will there be a corrosion issue between the dissimilar metals?
