GerryB
- woodbridge, ct. USA
My understanding is if you have in this case a 200 amp meter main outside the house and it feeds a 200 amp main lug panel, if you tap outside on the load side of the 200 amp breaker that you must add a 200 amp main breaker to the main lug panel inside. Is the reason that you could exceed 200 amps on the main lug panel without protection?. Thanks solar guys, trying to understand this.
