- If you splice a conductor to re-route a feed to a new location and install the same size wire at the splice - is it considered a tap? I'm assuming no because the overcurrent protection required for the "tapped" portion is the same as the original feed.
- I have a set of spare #4/0 conductors fed from a 200A breaker and abandoned in a j-box. I wanted to tap these conductors to feed a new 100A panelboard. If I splice and install #1 conductors I have to abide by the tap rule (NEC 240.21) correct?
- What if I install a MCB (where the tap conductor terminates) in the panelboard rated for 100A, does the tap rule still apply? I would think the MCB protects the upstream conductors from burning up. And since nothing else is on the feed the MCB should be sufficient.
- If I install the same #4/0 conductors as the original feed then the tap rule doesn't apply correct?
