Tap Meter Stack Disconnect Box for New Meter Stack
designer82
Boston
Is there any issues with tapping an existing meter stack disconnect box in order to feed a new meter stack?
Is this something electricians routinely do with no problems?
Here are some pics for more clarity:
Thank You
I think you'd need to start with a good old-fashioned load calc.
Is the box approved for adding load lugs to the busbars?
Thanks, I ran the load calcs. and loading is not an issue.
As far as your second question, I'm not sure. Any advice on this? Call/check with manufacturer?
This leads me to a new question. When adding the new branch ring, does it need it's own tap box to connect to or can it be any standard JB?
Please see pic for clarity
I would think you're restricted to the manufacturer's approved method(s) of supplying the stack.
