I have a switchboard that has an 800A main in it and nothing else.  My problem is that I need 800A OCPD to feed an MLO panel sitting right next to it (less than 10ft).  Can I use that 800A main and tap off the bus of the switchboard to feed my MLO 800A panel?
I believe 240.21(B) somewhat states I can from a tap rule standpoint. I was supposed to be supplied with an 800A disconnect and I was given a 800A switchboard to feed my panel with. It seems like this should be okay though since this is the only device that the switchboard will feed.
