aelectricalman
- KY
I have two buildings (on one property) that currenty have 2 services (500 amp and 200 amp). We are combining both services in the courtyard of the two buildings, and making it an 800 amp CT Cabinet and meter located on a new concrete pad. Immediately following is a new 800amp Service Entry Rated transfer switch. The transfer switch has only 1 Main circuit breaker. The problem is, I am delivering power to two seperate buildings. One building is a 500 amp panel, the other is a 200 amp panel. I am trying to stop short of installing an 800amp main lug Nema 3R $$$$$$ panel next to the transfer switch to house two breakers (500 amd 200 amp). I would land the 800amp feeders on the buss and distribute the power accordingly to both existing panels in the buildings (mains currently exist at both panels). I don't know everything about tap rules but my distributor is telling me that I can take the 800 amp feeder out of the transfer switch to a trough and tap the proper sized wiring for each panel according from the lugs, therefore alleviating the need to have a main lug panel next to the transfer switch. He put a couple people in touch with me that both told me it was ok to do. Tell me I'm not crazy! I can not see me taking an 800 amp rated wire(s) to a lug where I split it into a 500 amp rated wire(s) and a 200 amp rated wire(s), thus distributing these wires to the existing panels in the building. I do not buy that I can place a 3/0 copper for a 200 amp service and 2 sets of 4/0 copper for a 500 amp service on the same lugs with the 2 sets of 350kcmil for the 800amps service without having an overcurrent means between them. Granted both existing panels have overcurrent protection at the appropriate size, the wires from the trough feeding the two panels will not be rated at 800amps (the size of the main in the transfer switch). How is this ok? Does anyone have a code reference I can piggyback on? Thanks again.
