CustomElectricLLC
- Midlothian Texas
- Electrical Contractor
I’ve done my due diligence using the search functions but haven’t gotten a clear grip on this current setup I need to install.
ATS is SERVICE RATED. 320/400A meter/service w/ 2 existing MLO panels w/ 200A disconnects w/OCP. It has load side lug provisions for up to 250kcmil I believe to feed two separate runs to each panel/disco
To save time for everyone; 400A ATS is what I’m working with on this install.
Is there an issue with a tap rule being used in this setup where I would run feeder taps from the ATS to the disconnects which will then come out load side on discos and feed into panel. I’ve ready through 240.21 B 1 and don’t see anything that would be an issue. Taps will be less than 10’
Better yet I’m wondering if I can bypass 200A discos all together and install main breakers on the panels if possible to safe the extra stuff on the exterior
YES I am aware of the 83% rule of T310.12 A only limited to a feeder serving the entire load of the dwelling so I’ll be using 3/0cu on this install
TIA
TIA
