As Far I I can tell this situation will meets the NEC...
Does anyone see something that i don't.....
3 large Control panels ganged together left to right. The 1st panel has a 600A main breaker for the incoming feed sized according. In the same panel Installed off of that 600A breaker via 10 foot Tap Rule & Via Free Air Parallel #1's to a Power Distribution block. Distribution feeds about 305 amps of power to SCR controlled heaters individually fused @ 30A with multiple sets of #8 wire. From that same 600A breaker, tap off less than 10ft to feed a 100A and 150A breakers in the other cabinets all still less that 10 feet away . All panels have cable/door disconnect operators.
