dphill1301
- Watkinsville, GA Oconee County
I have a subpanel with a 125 amp main being fed from a 200 amp main panel. The wiring to the subpanel are correct in size and spliced above the main breaker of the 200 amp main using split bolt connectors. The sub panel is within the 25 foot rule and in conduit. The split bolt connectors are well insulated and protected inside the 200 amp panel. There is a disconnect between the meter and 200 amp main at the transformer on the street.
My question is. Is this a legal connection? If so, what code would it fall under? 240.21? or would it fall under a Line Side Connection Rule?
Tap Rules are a little confusing and any help would be appreciated..
