sesomkb
- Oak Ridge TN
- Electrical
Hello,
I'm looking over NEC 240.21(B)(5) for a tap rule. I have the following situation and want to know if it's permissible?
Situation: Incoming feeder from transformer to outside fused 800A disconnect is 480V. Secondary of this 480V fused disconnect will feed two 400A 480V panels inside of a building, cables will be protected in conduit. then from the 480V panels on to step down transformers, 208V panels, etc. length of feeder conductors to 480V panel will be greater than 25 feet.
Am I allowed to tap both feeds to the 480V panels from the secondary of the 800A fused disconnect and be code compliant or will I have to install one disconnect for each panel?
I'm still reviewing the NEC but appreciate any input here.
Thanks,
Thanks,
