DCorby
New member
- Colden, NY
As I was reviewing a new installation, I found that there is a 70A Circuit breaker from an electrical panel feeding a 480 VAC Disconnect. Tapped off the bottom of the disconnect there is a feed for a 480VAC -400VAC transformer feeding a piece of equipment. This feed goes to the machine main panel. Also tapped off the bottom of the disconnect is a 12 gauge 480VAC 3 phase circuit that feeds the machine main panel as well. It goes to a set of fuses that someone put in to run a mist collector that has a different voltage. The distance from the disconnect to the machine panel is close to 25 feet. Without pulling the wire, I cannot tell for certain. I personally don't feel it is good practice, but is it legal by the NEC? I am co0nfused as part of the rule states that you can not tap a tap?? Any assistance would be greatly appreciated.
