In a case where you have a 1200amp service being fed with 5 sets of 600mcm for vd, to a main disconnect which feeds a 800amp CT cabinet with 4 sets of 500mcm out of same 1200amp disco, and a 400 amp 3 gang meter bank being fed from the same 1200 amp disco by 2 sets of 350 mcm for vd all 3 phase fed through a 400 amp rated tap box to 3 meters each being protected by 3 - 200 amps breakers do you need a 400 amp main switch for meters if you are in the 10 foot rule, I say yes, but I was told no due to the 3meters only going to draw maybe 80 amps per, but being protected at 200 amps per. confused
