SECTION 240.21.B.2 #1; WHERE IT STATES, THE AMPACITY OF THE TAP CONDUCTOR IS NOT LESS THAN 1/3 OF THE RATING OF THE OVERCURRENT DEVICE. SO WHAT WE ARE SAYING IS THAT IF WE RELOCATE A 100AMP FUSED DISCONNECT 22 FT AWAY, THE TAP RULE APPLIES, THE SIZE(RATING) OF THE CONDUCTOR CANNOT BE LESS THAN 33.5AMPS. SO THE SIZE OF THE FUSES WE CAN PUT IN THE DISCONNECT IS 100AMPS. BUT IF THAT IS THE CASE YOU ARE NOT PROTECTING THE WIRE.
