I've been in the field a while but never applied the tap rules anywhere. I'm doing a job where a commercial building has a 400 amp service and wants a 100kw generator. The existing service splits below the meter with 3/0's going left and right to 2 200 amp fused disconnects, back into the same box below the meter and out the back to 2 200 amp panels. I need to put in a 400 amp transfer switch and feed the 2 200 amp panels.
First , can the service conductors pass thru the same box mounted below the meter? The code says they cant be in the same cable or raceway.
Second , can i apply the 10 foot tap rule , put a junction box on the 2 2" pipes near the panels, call them parallel feeds, splice them, and run 1 set of 3/0's to each panel?
I believe I can but I've asked a few people and thew all said their not sure but they also have not dont much in the way of taps.
Some help please?
Some help please?
