A 200A fusible disconnect is the disconnecting means for a building. The fusible disconnect then feeds a 200A manual transfer switch, which allows switching between utility and emergency power.
The manual transfer switch has two sets of lugs. One set to feed the main distribution panel with a 200A main breaker, and the other set to feed a 200A control panel. Do the NEC tap rules (240.21) come into play in this scenario at all? If so, how?
