Davebones
- North Of Tampa Fl
We have a air compressor that is fed from a 480 volt panel with a 400 amp breaker to a 400 amp fusible disconnect with 300 amp fuses inside . The original install has the disc feeding to the air compressor and they also feed #6 wire off the load side to a small panel next to the disc . In this small panel there's one 20 amp breaker that feeds an air dryer . Could these #6 taps that's that feed the small panel come off the line side of the disconnect and not violate tap rules ?
