Tap-Water Near Breaker Panel
No, as long as the water piping is not in the dedicated or working space of the panel.
i guess its the electricians choice, if there are PVC waterlines nearby that could possibly break, then I could simply refuse to put up a panel.
If you play the "could possibly" and "what if" game you will never get much work done.
Then "what if" you don't make any money, you "could possibly" starve to death.:p
If it's code compliant, then do the install. You can't outguess what might happen or what some (insert adjective) people will do after your install.
