JJWalecka
- New England
I have to mount some unistrut along a concrete ceiling. I want to use tapcons. Are tapcons list to be mounted on a ceiling? Thanks for your time
Sure, you are free to use tapcons. Fasteners are not required to be listed.I have to mount some unistrut along a concrete ceiling. I want to use tapcons. Are tapcons list to be mounted on a ceiling? Thanks for your time
What do the installation instructions for Tapcons say?
R
I was always under the assumption in a fire ALL the overhead lead anchors would fail. Im not a big fanSome anchors like the "lead nail ins" are not approved for overhead use. Not a fan of Tap Cons myself. They seem to be hit or mis with me. Sometimes good results sometimes not so good.
For concrete I like the steel drop ins
For Block & Brick the block anchors are good
The sleeve type anchors are pretty good for concrete or block but the stud size is smaller than the drilled hole
I dislike the sleeve stud anchors with the small sleeve they just seem to creep when you tighten them.
Appreciate your inputNot a big fan of Tapcons. Even using thier drill bits usually have problem with some stripping out or not holding. I'm old school and like using 1/4 & 3/8" lead anchors set by the Greenlee tool that threads into it before setting the anchor. Have installed 3/8" lead anchors in ceilings and tied pulling block to it to pull cable up to 4/0 copper. Several times I installed two 1/4" lead anchors to mount a piece of unistrut in a ceiling to hoist a drive weighting over 150 #'s.
