480/208/120 3-Phase 10kva transformer taps. What is the method for getting continuity from the taps over to the primary when there is varnish completely covering the tap?
I thought the removal of the varnish would create heat or a loss of voltage. The correct answer is that the varnish only provides environmental protection from harsh conditions suck as salt or extreme moisture.
In transformers and motors, varnish is used as the electrical insulation. It allows the conductors to be wound much tighter and closer than a plastic insulation.
