Can an Equipment Ground Conductor (EGC) be tapped or spliced in order to to ground multiple pieces of equipment or sturctures. For instance If I had a panel that had a feeder or branch circuit feeding a piece of equipment can the equipment ground conductor be tapped or spliced to ground surrounding structure in addition to the piece of equipment?
As another example can an inverter that has an equipment ground conductor on the DC side grounding the PV panels be tapped in order to ground the racking structure or supporting racking? Can this EGC be tapped several times to go in multiple directions to ground multiple panels and supporting structures?
If there are multiple inverters close to each other can the EGC's from the (3) inverters be combined into one with an irreversible splice to have the one EGC feed multiple panels and supporting structures?
