distriser
- Massachusetts
A row of exterior, pole-mounted light fixtures are supplied by the same single-phase branch circuit. The center fixture is wired directly to the electrical panel, and the fixtures on either side are supplied by conductors that tap off this center fixture. The conduit topology can be thought of as a 'T', where the vertical portion represents the connection between panel and center fixture. A cross-section of any of the conduits will always reveal (1) ground, (1) neutral, and (1) hot. Question is: where does NEC indicate this is permissible? 210.19(A)(4) doesn't seem to address it. Is it explicitly prohibited somewhere?
