whofrankw
- milford nj
A customer wants a 30 amp panel upgraded on a farm. They have a pole on the driveway with a two hundred amp line that taps in multiple directions..house, and a couple barns and garages. In one direction a line is run to a small cottage and tapped to a garage which has the 30 amp panel. So basically a bunch of taps at the pole, then one to a cottage with a tap to the garage. I think the triplex is a #4 aluminum. its old and I wouldn't know until I open it. Would I be able to put a 60 amp breaker out there with this line or since the cottage is there I would need to run a new line to the pole. (Im trying to avoid that)
