Carultch
- Massachusetts
Suppose you have 3 parallel sets in a feeder, and you plan on tapping a circuit that also has 3 sets in parallel. Provided that you preserve the symmetry as much as practical, is it code compliant to make individual wire taps, as an alternative to a complete 9-terminal device that would join all of them together?
This question would also apply if there is any common factor between the sets you are joining. Obviously tapping 2-sets onto 3-sets requires an 8-terminal block to join them all together (3 in, 3 out, 2 tap), because 2 and 3 are both prime. But because 2 and 6 have the factor of 2 in common, if you plan to tap 2 sets onto 6 sets, would have this question apply, in order to connect each tap set onto a group of 3 sets from the feeder.
