hhsting
- Glen bunie, md, us
- Junior plan reviewer
Attached sketch shows 400A fused service disconnect feeding a trough which is tapped to tap conductors to 225A ATS and to fused disconnect to RTU. Load side of ATS is then fed thru another trough which is then tapped again to panelboard and to fused disconnect.
Questions are following:
1. Tap conductors to ATS does code require 225A breaker between trough and ATS? If yes then which code section.
2. Looks like tap of a tap but not sure since ATS comes in between. Is this tap of a tap? If yes then which section of 240.21 is violated?
3. Would it be tap of a tap if 225A breaker is provided between trough and 225A ATS
4. Is their any other code violation being done here?
Thanks for your input
