Disconnect fed from circuit breaker in panel. Coming off line side in disconnect to another disconnect (fused). Disconnect #1 is fed with #4 thhn cu.
Disconnect #2 is fed with ?#10 or ?#12 . I couldnt get up to it today to see for sure. Disconnects are maybe 10ft apart.
Is this a correct tap scenario? I am getting a bit turned around in the tap rules. Thanks for any help.
