My question is I have an 800 amp 120/208v 3ph Wye service with an 800amp main breaker disconnect feeding 4-200amp MB subpanels being fed with seperate runs of 4-3/0 cu conductors & a #6grnd in 2" EMT, it is 32' to the last subpanel. My inspector is referring to article 240.21 (B)(2) as a failed inspection, I have tried to convince him that this scenario has nothing to do with the tap rule because I have overcurrent protection devices on both ends. I have the 800 amp Main breaker and the 4-200amp main breakers for the sub panels. Does anybody have a code reference that I can use to help me out?
