Two question related with two examples
1) A video screen controller is mounted above a tbar ceiling and the screen is just below it. Can you run flexible cord down through the tbar to feed the screen or do you have to mount a jbox in the tbar above the screen to feed it. I believe the code says no but I am wondering why in this case.
2) Can you mount a 120 volt receptacle above the tbar ceiling for the power cord on a projector? In this example the power cord runs up through the pole that the projector is mounted on and plugs in just above the ceiling. Or, do you have to install a jbox in the tbar ceiling and install a receptacle in that?
