Stephen Tishhouse
- Kalamazoo Mi.
I have a appartment (100 apartments) project where the mechanical contractor is adding AC split units. It is in his contract to instal the head or the unit inside and the control wire to it. So he installed Tray cable with the line set to all the inside places (2 per outside unit he has 20 installed). The iElectrical inspector has came on site for my work and looked at his work, and has told him that he also needs to pull a permit for his control wire to the head in, and also that he needs to change all the tray cable. His supplier sold the TC to him. I called up several mechanical contractors and all use TC cable. I also talked to a few other inspectors in other areas and they say that they always let the TC be installed. I do see that it does not meet the NEC standards. What is your thoughts on this?
336.12 Uses Not Permitted.
Type TC tray cable shall not be installed or used as follows:
(1) Installed where it will be exposed to physical damage
(2) Installed outside a raceway or cable tray system, except as permitted in 336.10(7)
(3) Used where exposed to direct rays of the sun, unless identified as sunlight resistant
(4) Direct buried, unless identified for such use
336.10 Uses Permitted.
Type TC cable shall be permitted to be used as follows:
(1) For power, lighting, control, and signal circuits.
(2) In cable trays.
(3) In raceways.
(4) In outdoor locations supported by a messenger wire.
(5) For Class 1 circuits as permitted in Parts II and III of Article 725.
(6) For non–power-limited fire alarm circuits if conductors comply with the requirements of 760.49.
(7) In industrial establishments where the conditions of maintenance and supervision ensure that only qualified persons service the installation, and where the cable is continuously supported and protected against physical damage using mechanical protection, such as struts, angles, or channels, Type TC tray cable that complies with the crush and impact requirements of Type MC cable and is identified for such use with the marking Type TC–ER shall be permitted between a cable tray and the utilization equipment or device. The cable shall be secured at intervals not exceeding 1.8 m (6 ft). Equipment grounding for the utilization equipment shall be provided by an equipment grounding conductor within the cable. In cables containing conductors sized 6 AWG or smaller, the equipment grounding conductor shall be provided within the cable or, at the time of installation, one or more insulated conductors shall be permanently identified as an equipment grounding conductor in accordance with 250.119(B).
Exception: Where not subject to physical damage, Type TC-ER shall be permitted to transition between cable trays and between cable trays and utilization equipment or devices for a distance not to exceed 1.8 m (6 ft) without continuous support. The cable shall be mechanically supported where exiting the cable tray to ensure that the minimum bending radius is not exceeded.
(8) Where installed in wet locations, Type TC cable shall also be resistant to moisture and corrosive agents.
FPN: See 310.10 for temperature limitation of conductors.
(2) In cable trays.
(3) In raceways.
