Grouch
- New York, NY
Hey all,
I have 2 questions of the TCC curve that you'll find on page 5 of the PDF in this link: (i have yet to master attaching a pic! the file sizes are too large)
http://www.eaton.com/ecm/idcplg?Idc...eleased&Rendition=Primary&dDocName=TD012019EN
#1) If you look at note 8 on the right (it's not labeled with an '8', but you'll see the paragraph start right below the number 7.. looks like a typo), it says "When rated amps (Ir) is set to the maximum position (position H), then both the SDPU and the Instantaneous Override pickup are equivalent. Therefore, the breaker will trip on Instantaneous Override." Does this mean that for a 600 amp breaker, even though my Short time pickup is set at 6, for a value of 600 x 6 = 3600 amps for the pick up, that pick up is nonexistent? so there is no short time pick up, but rather only instantaneous pickup at 600 x 12 = 7200 amps?
#2) There are 3 settings for short time delay: instantaneous, 120ms, and 300ms (shown on the graph)... is this truly considered 'instantaneous"?... it starts at around .04 seconds. If you go further down the chart, the actual instantaneous region picks up at .01 seconds.
Thanks!
Thanks!
