TECL required at Refinery, Gas, chemical plants, for low voltage installations.
JD_control_spark
New member
Spring, TX
I work with a company that does control, signal communications installations (PLC's, control panels and such). We fabricate the panels at our shop and install out in the field. I know that doesn't count as electrical work since its industrial network systems, but if you have to run a 120VAC circuit to power up your panel, does that require you to have a TECL????? The company is bonded 3x than the TDLR minimal insurance coverage.
I've looked all over City of Houston Electrical Division rules, and TDLR, and I can't seem to get a clear answer .
Any thoughts would greatly be appreciated!!
Thanks!
TECL = Texas Electrical Contractors License?
My guess is that all of the field work you are doing is supposed to be done by someone with a TECL if you are an outside organization coming in to a location and doing this kind of work.
How do you get a permit without a contractor license?
