I'm hoping someone has run across this issue.
ANSI-607 2011 (a bit old) figure 2, example of a large building, shows a bonding conductor between TGB and building steel. Although the BCT and its size are defined in 6.3.3, the size requirements of the bonding conductor to building steel is not covered in this document.
I googled about this and found multiple sites that reference this standard stating that a #6 should be used, not a minimum #6, but specifically a #6 (regardless of the TBB and GE size).
Does anyone know if the size of this conductor is provided in any version of this or any other standard?
Any guidance on this would be appreciated. Thanks,
Patrick
Patrick
