Sparky2791
- Northeast, PA
- Electrical Design
I have a project where telescoping bleachers will be used. Manufacturer's engineering department said on the phone they just need a junction box to tie into, a knife switch disconnect is not required. It is a 3 phase circuit, 4 wire, they need the neutral. Their control box holds the thermal overloads and control for the motor which is a 1/2 HP motor. Typically I would just add a disconnect and be done with it but in this case I would have to install it behind the bleachers making it not readily accessible. I cannot install to the side of the bleachers for other reasons.
Does it need a disconnect? I thought I read something in the NEC about fractional HP motors not requiring a disconnect switch.
The panel is not within sight of the bleachers.
Thanks for the reply's!
