pipe_bender
- Boston
- Electrician
I installed some temp power for a residential remodel, they are going to need a 240V floor sander so I put in a 50A 240V receptacle and some regular GFCI's, I had some other work inspected which passed but the inspector noted Temp construction power
"--Corrections needed provide copy of assured equipment grounding program or GFCI protect temp power."
The only outlets not GFI was the 240 one.
Do all 240V temporary outlets on a jobsite actually fall under the NEC ? I thought it was 10 - 30A 120V?
Its going to be removed before the inspector even returns but I deal with this town inspector pretty regularly so wanted to see if this was in the NEC or a local thing.
