scott minter
- Kennedy Space Center, Florida
- Associate Engineer
Good Morning
I have noticed using EasyPower software the default setting for field temp of conductor is 50c.
In discussions with an engineer at our company he say E Tap defaults to 75c.
We have done some research and came across a GE white paper that says you should use 30c.
EasyPower has options all the way from 25c to 250c.
Depending on the setting it changes the resistance and and the indecent energy level.
My question is there a hard standard we should be using ?
Thank you for the help.
