- Tennessee NEC:2017
- Semi-Retired Electrician
Any one know where I can find a metered temp panel? I have temps out on job sites but need another and I can't find one here or even all the parts to make something similar.
If I could find a 100A meter base, then yes. Normally here, they wouldn't accept a larger meter base, but with supply shortages they are letting some things go.Can't make one with a 100a meter base and a 100a small panel?
Yes, I actually contacted one of my inspectors and he said they are accepting most anything (within reason) since material is so hard to get.Can you use a 100 amp meter main and install 2-20a breakers instead of a 100a main?
Siemens 100 Amp 2-Space 2-Circuit OH Fed Surface Mount Ring Type Meter Main MM0202ML1100S - The Home Depot
Siemens Meter Main and Meter Load Center Combinations provide a full range of Metering Products that are built for safety ease of installation and long term quality. A Meter Main is a device that provideswww.homedepot.com
I've been buying a lot on Amazon these days, sometimes I have to order a 50A GFI Breaker from Indiana or panel from Ohio.supply shortages they are letting some things go.
