shockking
- Sacramento, CA
- engineer
Does anyone apply temperature derating for transformers, conductors, etc. that are installed in direct sunlight?
I've seem forum discussions that suggest adding anywhere from 5°C to 40°C to the ambient temperature; that makes sense to me, but I haven't found anything to advise on exactly what value to pick in that range. Is there another way to go about this, or any suggestions on how to pick a modifier?
I have some oil filled transformer in operation, in direct sunlight. For existing installations, I could collect some IR surface temperature measurements (with or without load) and see what the surface temperature is reaching. For these xfmr's I can look directly at the oil temperature, but it's a lot easier to collect surface temperature than oil temperature data. Is the surface temperature the right measurement location to compare with the ambient temperature rating in the specs for a transformer? (i.e. Is there a way to measure "effective ambient temp in direct sunlight" or should I just take an air temperature and add a modifier?)
