I'm reading that a conductor that has a load at it it's 90 degree C ampacity will cause the conductor to operate at 90 degree C. Not a code question, but I never thought of it that way before. For instance, a 55 amp load on 8 AWG will cause the conductor to operate at 90 degree C. Seems simple but now it makes sense that you use this conductor on equipment terminals rated for 75 degree C because they will fail due to the temperature rating.
