Well, there's 'theory,' and there's 'real world.' I guess you really need to know first is: what is the question you want to ask.
Breakers are calibrated at 20C (about 68F). That means it will perform to the advertised trip curve at 68F. Make it hotter, and it will trip sooner. In extreme situations, this can be a cause of nuisance tripping. Selecting OCPD's for high ambients can sometimes be a challenge. Extremly low temps have the opposite effect- the breaker won't trip soon enough.
The connections on breakers are usually rated at a much higher temperature. Commonly 75C / 135F, this means that at about 135F things in the breaker start failing. Plastics char and become brittle, etc. Parts within the breaker generally become hot because electricity is flowing through them.
What does this mean to you? Well, it means that a high ambient can be the cause of problems. It also means that places that are noticeably hotter than the parts around them need extra attention; there might be a problem brewing.
It's not enough to say "My IR camera says the breaker is 121.37F" So what? Maybe it's supposed to be that warm. OTOH, if everything else in the panel is 90F, and the hot spot is where the wire connects .... maybe the screw is loose.
