Temperature Triggered Electrical Switch
Bama_Electrical
Alabama
I am wrapping up the install of a data closet for a customer and they asked if I could install a vent fan for venting heat out if the temp reached a certain temperature in the closet. Has anyone used a temp control switch for a vent fan?
Depending on the temp setting desired you might just be able to use an attic vent exhaust fan with thermostat included
DIN rail mount? Panel mount?
they are common for all types of installations.
Depending on how big the closet is and how much equipment is in there, that fan might need to be on all the time.
Or even a small mini split.
