jim@airportelectric.com
New member
- El Segundo,CA 90245
I want to connect a temporary generator (floating conductors) to supply a 240 volt midpoint ground (high leg) system. Can I ground the system by connecting 2 of generator legs to the secondary windings of a single phase 240 to 240/120 transformer and connecting the neutral tap to the neutral of the building panel which I assume is grounded. I will check this before proceeding. What about capacity? Do the windings need to be able to carry the max unbalanced current between the (2) 120v to ground legs? Would it be better to use the secondary of a 3 phase 240 volt high leg transformer connecting all 3 generator legs. I don't know if it is important to consider phase angles etc. Thanks for any help. Any other solutions?
Jim
Jim
